Ninovan
Oct 07, 2018Star
Why is my network map wrong
With the last update my Orbi reports that NOTHING is using my satalites. It shows everything connected to the base. I know this is wrong as each base has at least one PC -Wired- to it as well at cl...
Ninovan
Oct 07, 2018Star
Ah setup...
/ Satalite #1
Comcast modem >> Orbi <
\ satalite #2
we have about 25 devices, a mix of PCs, amazon echos, cameras, VoIP boxes, media players, smart TVs, iPads, iPhones, printers, plotters, NASs, and an automation server... and a partridge in a pair tree.
the devices are even distributed about the house, so they should be distributed evenly umong the Orbi devices as well...
cool2562
Oct 07, 2018Star
If you upgraded to the new firmware you will need to restore to factory defaults and set up from scratch.
- NinovanOct 08, 2018Star
The network counties to function well, everyone is happy with the stability and speed, its just when I go to look at the network to try to head off any problems, the layout is wrong. I know the satalites are working as there are PCs connected to them that are working fine...
if if I didn't go wandering looking and trying to learn I would never know..
