Ninovan
Oct 07, 2018Star
Why is my network map wrong
With the last update my Orbi reports that NOTHING is using my satalites. It shows everything connected to the base. I know this is wrong as each base has at least one PC -Wired- to it as well at cl...
Oct 08, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
