prodport
Oct 17, 2019Initiate
Why isn't ORBI Login Secure
I like the product but why is the browser login for Orbi insecure? (http://orbilogin.net/adv_index.htm). IF I change to HTPPS I get a different error. I don't use the phone app becasue I find t...
- Feb 14, 2020
willemdh wrote:
HTTPS is really important and should also be enabled inside the network. otherwise the password used when logging in, can easily be sniffed by bad actors..
Please add this feature asap...
Done!
It works already. The ugly thing, however, is that Netgear has totally messed up the SSL Certificate on the Orbi line, so modern browsers like Chrome will complain, "The Cert is bad. Don't go there! Oh, no. The sky is falling."
Try it for yourself: https://orbilogin.net. Just ignore the warnings and proceed to the Orbi Home Page. Works great!
Oct 18, 2019Guru - Experienced User
Any problems from using HTTP on the LAN side would only be seen on the LAN side. When remoting in from the WAN side, HTTPS is used. LAN side connection to the routers weg page would not be seen of the WAN side. Thus again, not a major or critical issue to use HTTP for router web page use.
- Retired_MemberOct 18, 2019
FURRYe38 wrote:Any problems from using HTTP on the LAN side would only be seen on the LAN side. When remoting in from the WAN side, HTTPS is used. LAN side connection to the routers weg page would not be seen of the WAN side. Thus again, not a major or critical issue to use HTTP for router web page use.
Huh...??
who logs in to their Orbi remotely?
- michaelkenwardOct 18, 2019Guru - Experienced User
Retired_Member wrote:
Huh...??
Strange question.
Anyone who needs remote access.
- CrimpOnOct 18, 2019Guru - Experienced User
who logs in to their Orbi remotely?Actually, it appears enough people want to log in to their router remotely that Netgear provides an option specifically for it, on the web interface and on the app interface.
I set up an Orbi 3,000 miles away and need a way to administer it without taking an expensive flight. We have had numerous questions on the forum from people who have rental property and offer WiFi. I agree that the vast majority of WiFi owners never look at their WiFi once it is set up, and the vast majority of those who do are on the "inside" of the WiFi.
OK....put me down has never had the 'need' to do this. For those that do, then the need for security can be an issue.
