sh2sg
Nov 26, 2018Apprentice
Why RBR50 gives a different DHCP IP?
Orbi router acts as AP mode.
The Orbi admin connection status page says DHCP server IP 192.168.0.1 (which is out of local IP range).
On the Mac "ipconfig getpacket en0" says DH...
sh2sg
FURRYe38 wrote:
Whats the Mfr and model# of the main host router the Orbi is connected too? What is IP address pool string? .1.1?
You sure the Orbi router IS in AP mode? When in AP mode, it should be disabling it's own IP address pool server and passing along what is coming from the main host router, i.e. .1.1
Is odd that is showing this .0.1 from a DCHP server.
Router is Zhone, it is a Fibre Modem + Router 2-in-1 device.
Orbi is in AP mode since always. Zhone Router IP range from .1.1, Zhone Router IP 192.168.1.1, all connected devices IPs are from 192.168.1.11.
I login to Zhone Router's config page, DHCP IP is 192.168.1.1 as expected, dunno why Orbi shows a wrong DHCP IP, but I don't see any problem assigning IP to new connected devices. To me it looks like Orbi display issue...
Nov 26, 2018Guru - Experienced User
Possible. If everything is working, I wouldn't worry about it too much.
