OrbiisaPOS
Apr 08, 2018Tutor
Why the hell is connecting a printer to an Orbi such a frustrating ordeal?
I've got an RBR 50 with one satellite. The router is connected to my Comcast modem. I recently bought an Epson ET-3750 printer/scanner/copier. I was initially able to get it set up and it worked g...
Apr 08, 2018Guru - Experienced User
THis doesn't involve any FW editing as you cant do this anyways. More like what is the Mfr and model # of the ISP modem? Seems to be a built in router here maybe?
Which router did you have the printer set up too? The Modem or the Orbi router?
Wired or wireless connection with the printer?
Try resetting the printer and setting it up from scratch? Make sure your connecting it to the Orbi system and not the ISP Modem.
OrbiisaPOS
Apr 09, 2018Tutor
The ISP modem does have a built in router but I've disabled the wireless broadcast. I ended up starting from scratch and reinstalling the printer. It's a wireless printer. It just took way longer than it should because it randomly wouldn't recognize the correct network and then suddenly it would. And now if the power ever blinks off I'll be in the same boat again because it won't reconnect on its own.
Maybe "editing firmware" isn't the correct terminology, but this is what I was referring to: https://community.netgear.com/t5/Orbi/Epson-ET-3600-printer-has-issue-with-Orbi-RBK50-single-SSID/td-p/1321524
My point remains, though, that it's ridiculous that Netgear doesn't acknowledge this issue and has done nothing to address it.
