Zookeeper4Life
Aug 12, 2019Follower
Why would Orbi system keep loosing it connecitivity
I purchased my Orbi (RBK-43-200NAS) a few days ago as I was told it was very easy to setup. well I followed the easy to set up instructions yet, my system is constantly loosing connectivity. If you do...
Aug 13, 2019Guru - Experienced User
What do you mean by lose connectivity? Wireless and wired?
What is happening when this appears? Need more information to help you out.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Zookeeper4Life wrote:
I purchased my Orbi (RBK-43-200NAS) a few days ago as I was told it was very easy to setup. well I followed the easy to set up instructions yet, my system is constantly loosing connectivity. If you don't have a teenager in the house be glad, because its a bad situation when they have no internet. what type of garbage did I buy Netgear?
