XBond
Nov 08, 2019Apprentice
Wi-Fi calling drops and reconnects continously
I see other posts on this issue, but wondering if anyone has updated/recent information on this issue. I have an Orbi RBR50 with a single satelite. The router sits on my desk, and my iPhone 11 Pr...
- Nov 13, 2019
Turning off Daisy Chaining and Enabling Fast Roaming has made a huge difference.
Wi-Fi calling still drops out once in a while but not nearly as frequently.
Retired_Member
Nov 08, 2019How long have you had this problem? Has you network ever worked fine?
What type/model modem?
- XBondNov 08, 2019Apprentice
My network works flawlessly in general. I have never had an issue with my setup. Wi-Fi speeds are fantastic and consistent.
I have had this issue for the past year since we switched to T-Mobile. Did not have Wi-Fi calling with our prior carrier.
Using an XFinity cable modem in bridge mode.
- Retired_MemberNov 08, 2019
OK...sounds good.
Glad things are working other than wifi calling.
There have been some issues with v2.3.5.50. Did you install it manually or was it pushed automatically?
If others don't chime in here you may want to do a search on wifi calling.
The fw update was pushed automatically, but I believe this issue has been happening since prior to that release.
I did do a search on Wi-Fi calling, but unfortunately nothing concrete came up. Just a lot of try this, try that, might help, might not.
I have not done a factory reset and would rather not have to if I can avoid it.
