XBond
Nov 08, 2019Apprentice
Wi-Fi calling drops and reconnects continously
I see other posts on this issue, but wondering if anyone has updated/recent information on this issue. I have an Orbi RBR50 with a single satelite. The router sits on my desk, and my iPhone 11 Pr...
- Nov 13, 2019
Turning off Daisy Chaining and Enabling Fast Roaming has made a huge difference.
Wi-Fi calling still drops out once in a while but not nearly as frequently.
Nov 09, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
XBond wrote:I see other posts on this issue, but wondering if anyone has updated/recent information on this issue.
I have an Orbi RBR50 with a single satelite. The router sits on my desk, and my iPhone 11 Pro Max is no more than 5 feet from the router. The iPhone is connected to the router.
I have T-Mobile Wi-Fi calling enabled. The connection drops/reconnects constantly which is extremely annoying as it happens frequently while during a call. The same issue happened with my iPhone 8.
Settings attached.
Router and satelite running latest firmware v2.3.5.50.
Retired_Member
Nov 09, 2019
FURRYe38 wrote:What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Settings attached.
what more questions and questions.....!!!!
