XBond
Nov 08, 2019Apprentice
Wi-Fi calling drops and reconnects continously
I see other posts on this issue, but wondering if anyone has updated/recent information on this issue. I have an Orbi RBR50 with a single satelite. The router sits on my desk, and my iPhone 11 Pr...
- Nov 13, 2019
Turning off Daisy Chaining and Enabling Fast Roaming has made a huge difference.
Wi-Fi calling still drops out once in a while but not nearly as frequently.
SW_
Nov 10, 2019Prodigy
Try to turn off celular on the phone to prevent it from switching between celular/WiFi, i.e., forcing it to stay on WiFi calling. If you've already tried this, please ignore.
XBond
Nov 13, 2019Apprentice
- FURRYe38Nov 13, 2019Guru - Experienced User
Also did you try turning off celluar features as suggested to see if this also helps?
You also might set up an IP address reservation for your phone(s) ON the RBR as well. Under Advanced tab/Settings/LAN Setup.
Glad its working better for you.
XBond wrote:Turning off Daisy Chaining and Enabling Fast Roaming has made a huge difference.
- XBondNov 13, 2019Apprentice
I did not try turning off cellular features as it is not really a long-term viable solution for the household. :smileyhappy:
I might try the IP reservation if the current situation is not workable, but so far it is working well.
Thanks for the suggestions.
Glad the suggestions work though.
Please mark your thread as solved so others will know.
Enjoy.:smileywink:
