Superdave132
Jul 16, 2020Aspirant
Wi-fi channels performance
After installing firmware 2.5.1.32, I chose channel 11 but when I use a bandwidth monitor it shows me on channel 11 but the channel graph shows me on 9 with a frequency footprint from channel 5 to 13...
- Jul 18, 2020
Thats now those apps display wifi signal is all. Has nothing to do with Orbi.
Jul 16, 2020Guru - Experienced User
What app are you looking at?
What does your Advanced Tab on the RBRs web page look like?
It should appear as 11(P)+#(S) # being maybe 7 or 9
Superdave132
Jul 17, 2020Aspirant
Wifiman test results show the same thing.
