ECecil
Oct 04, 2018Aspirant
Wi Fi dropping
Installed this system yesterday - connected devises constantly losing wi fi connection, wi fi calling drops calls.... especially when walking around the house. We have two satellites.
Oct 05, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
