iancooke101
Dec 31, 2016Initiate
Wi fi drops
Hi, pretty new to this so hoping you can help. I've installed the Orbi and all appears to be fine except the wifi connection from the Satellite is ridiculously intermittent. Quite literally will swit...
iancooke101
Jan 04, 2017Initiate
Thanks for your reply. Logistics of the house mean they are as close as they can be. Light comes on blue so I'm assuming the proximity between router and satellite is ok. In terms of adjusting wireless channels do you mean set the Orbi to channel 1,6 or 11 via admin settings and / or on my BT broadband router which in turn connects via Ethernet to the Orbi router? Not sure if I need to change channel settings on both? Thanks.
DarrenM
Jan 10, 2017Sr. NETGEAR Moderator
Hello iancooke101
you would just need to adjust the channel on the orbi.
DarrenM
