pxlla
Feb 16, 2022Tutor
Wi-Fi faster than ethernet
My ISP is Spectrum in Los Angeles. Previously, my CBR40 worked fine, however I noticed that the speed for downloading is now at 90Mbps when connected to Ethernet and 475Mps when connected to Wi-Fi. ...
Feb 17, 2022Guru - Experienced User
Do the wan statistics page when a device is plugged into the port
pxlla
Feb 17, 2022Tutor
Here's the WAN info from the statistics:
- plemansFeb 17, 2022Guru - Experienced User
Get the whole wan/lan. Trying to find out what the lan is showing up connected at while a device is plugged in.
- pxllaFeb 17, 2022Tutor
Thanks for being so patient, this is all new to me!
- FURRYe38Feb 17, 2022Guru - Experienced User
What ever is pluged into LAN port 1 is only connecting at 100Mpbs and not at 1000Mpbs.
try replacing the cable with at least a cat 6 cable. And try it on different ports to see if its related to the port.
Thanks for your help, I checked that I'm using a CAT6 cable and also tried different ports. Still the same.
- plemansFeb 18, 2022Guru - Experienced User
when you switch ports, does the other port switch to 100mbps connection?
do any devices connect at gigabit speeds under the statistics page?
