Yorkshirepud00
Dec 17, 2019Aspirant
WI FI frequency
HI could some help i am trying to set up my home with wi fi switches and they only work on the 2.3GHz how fo i split the SSID so i can pick this because they dont work on 5GHz Thanks advance for...
Dec 17, 2019Guru - Experienced User
What is the Mfr and model of these "WiFi switches"?
There a link to there web site support page?
Orbi doesn't allow to separate the SSID names officially on Orbi. However you can do this:
Once you turn OFF The 5Ghz SSID broadcast, you should be able to setup the 2.4Ghz devices on Orbi.
Yorkshirepud00 wrote:HI could some help i am trying to set up my home with wi fi switches and they only work on the 2.3GHz how fo i split the SSID so i can pick this because they dont work on 5GHz
Thanks advance for any help
Lee
