Yorkshirepud00
Dec 17, 2019Aspirant
WI FI frequency
HI could some help i am trying to set up my home with wi fi switches and they only work on the 2.3GHz how fo i split the SSID so i can pick this because they dont work on 5GHz Thanks advance for...
CrimpOn
Dec 17, 2019Guru - Experienced User
First, make certain that there is actually a problem. Manufacturers emphasize (in LARGE TYPE) "Requires 2.4G Network. Does not work on 5G!!!" and people panic. Well, Orbi (and all of the other modern mesh routers) provide both 2.4G and 5G networks. So, you have a 2.4G network, just what the device needs. Chances are that when you go to set up the device, it will discover the Orbi network and be fine. My five brands of smart plug and several brands of video cameras did.
For those rare instances where the smartphone setup program fails, the simple remedy is to use the Orbi web interface to temporarily stop broadcasting the 5G SSID. Tell the smartphone to "forget" the Orbi network and then join it again (at 2.4G). After the device is set up, go back to the web interface and resume broadcasting the 5G SSID.
Yorkshirepud00
Thanks I will give it go tomorrow and let everyone know how i get on.
- FURRYe38Dec 17, 2019Guru - Experienced User
:smileywink:
- CrimpOnDec 17, 2019Guru - Experienced User
Please report back with your results. Many people feel strongly that some devices are impossible to connect without hacking the Orbi. If your device simply will not connect, I'd like to know what it is.
- michaelkenwardDec 18, 2019Guru - Experienced User
I second that. We need real evidence to be able to get this sort of thing sorted put.
Some people have claimed that it is impossible to get some IoT things to work on a mesh network, but as yet no one has come up with a single device that really does refuse all approaches.
- Yorkshirepud00Dec 18, 2019Aspirant
Sonoff 3 gang switch, looks a good bit of kit if i can get it working,
- CrimpOnDec 18, 2019Guru - Experienced User
At what point in the setup did it fail?
I'd also like to know which specific "Smart Life" app you are using. I purchased a Teckin outdoor smart plug that had me install Smart Life, version 3.13.6 by Tuya, Inc. If I recall correctly (it has been months), this might have been the app that kept warning me "Only support 2.4G", and I just kept pressing "Continue". It is now outside controlling my Christmas lights. I did the setup on my Sony smartphone, which was connected to my Orbi at 5G.
The Amazon web page offers some advice:
"WiFi name should only contain letters and numbers. NO special symbol allowed (Like a dash.)"
and
" Any question you are welcome reach us via: 【[email protected]】, We will solve it immediately until you are 100% satisfied. "
