Yorkshirepud00
Dec 17, 2019Aspirant
WI FI frequency
HI could some help i am trying to set up my home with wi fi switches and they only work on the 2.3GHz how fo i split the SSID so i can pick this because they dont work on 5GHz Thanks advance for...
Yorkshirepud00
Dec 18, 2019Aspirant
I have tried what you said but it did not work i even checked that the router was on the 2.4 by looking it up on my Laptop do you think it colld be a switch faulty, could i ask you what make you have installed to yours its a light switch i have bought a Sonof
I want to go wireless on all the switchies in the house but just thought i would buy one to see what its all about and how they work,
whats your thoughts
michaelkenward
Dec 18, 2019Guru - Experienced User
Yorkshirepud00 wrote:
I have tried what you said but it did not work i even checked that the router was on the 2.4 by looking it up on my Laptop ...
What do you mean by that?
It is not clear from your message that you turned off the 5 GHz SSID broadcast.
