DogFog
Mar 06, 2020Aspirant
Wi-Fi Performance Recently Degraded Severely - Orbi RBR50 V2.5.1.8 (RBK50-100NAR)
In the past week or so, my wi-fi performance has become very unreliable on my Orbi RBR50 system. This includes on my laptop which is on the desk directly next to the main router. My desktop computer ...
Mar 06, 2020Guru - Experienced User
"my work wi-fi router" How close is this to the RBR? Having other wifi radios near by can cause problems. Channels differ from what Orbi uses?
What speeds do you pay for UP and DOWN from your ISP?
DogFog
Thanks for the quick replies.
The modem is mine and is a Netgear CM500.
The number of neighboring wi-fi networks fluctuates, but is usually about 3 or 4.
The satellite is about 40 feet away.
I pay for 175 Mbps down / 5 Mbps up (Comcast Performance Pro). Speed Tests on the Orbi app are usually in the range of 150-210 Mbps down / 5-6 Mbps up. Right now, head-to-head, I'm seeing:
- Orbi app on iPhone: 209 Mbps down / 5.5 Mbps up
- Ookla site via work wi-fi on laptop: 47 Mbps down / 6.0 Mbps up
- Ookla site via Orbi wi-fi on laptop: 40 Mbps down / 6.0 Mbps up
So it's comparable right now. But there are times when the Orbi wi-fi won't load pages at all, and my work wi-fi performs just fine.
The work wi-fi router is on my desk a few inches from the Orbi, but nothing about this set up has changed in the past year. I have a separate wi-fi for work because I work from home most of the time and it automatically puts me on a secure connection to the company network without needing to run a VPN client (Cisco Meraki).
Nearby channels, per the Mac OS X Wireless Diagnostics Utility Scan, are:
- Orbi network (2.4 GHz) on channel 4
- Orbi network (5 GHz) on channel 48
- Work network 2.4 GHz) on channel 1
- Work network (5 GHz) on channel 149
- Neighbor network 1 (5 GHz) on channel 36
- Neighbor network 2 (5 GHz) on channel 36
I have not yet performed a full factory reset.
