NikolajLunoe
Apr 05, 2019Aspirant
Wi-Fi signal disappears, probably due to too many competing devices – or could there be another expl
I am afraid I already know the answer to the following question (and that it cannot be mended), but thought I would check this with someone more knowledgeable than me anyway.
I live in a 96-squ...
Apr 05, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
