Magoo150
Sep 12, 2019Aspirant
Wi-Fi speed
I have the RBK50 and here recently my Wi-Fi speed is only topping out at 304 mbps. Before I could get 500 to 700 mbps connection to the router. I use the app Wi-Fi SweetSpots to see connection speed. ...
Magoo150
Sep 13, 2019Aspirant
It still tops out at 304 mbps, and that right next to the satellite. I use Wi-Fi SweetSpots to find any dead zones in my house. Everything was fine and dandy until I enabled NETGEAR Armor. The link rate is half what it used to be. I appreciate the help hopefully I can figure this out soon.
Sep 13, 2019Guru - Experienced User
Armor has been know to cause problems. I recommend that you factory reset the RBR and RBS and setup from scratch. This time do not enable any Armor or Circle apps.
