gadabout
Aug 05, 2019Aspirant
Wie viele LAN-Verbindungen sind beim RBS20 möglich?
Wie im Titel bereits beschrieben, interessiert mich wie viele Geräte man (ohne Switch) an einen Orbi RBS20-Satelliten hängen kann. Ich weiss, dass zwei RJ45 Stecker vorhanden sind aber manchmal ist vo...
- Aug 05, 2019
gadabout wrote:
As described in the title, I'm interested in how many devices you can hang (without a switch) on an Orbi RBS20 satellite. I know that there are two RJ45 connectors but sometimes there are two LANs, sometimes a LAN and a WAN port. Can the WAN port be used for connecting an additional client or is it only for connecting a satellite via LAN to the router?RBS20 (Orbi Satellite) has 2 LAN ports that you can use to connect wired devices to.
RBR20 (Orbi Router) has one LAN port and one WAN port. The WAN port can only be used to connect Orbi to the ISP modem/router (internet source).
ekhalil
Aug 05, 2019Master
gadabout
Wow, that was fast. Thanks for the clarification!
