Fasco82
Dec 14, 2019Follower
WIFI 2.4 AND 5
Hi at all ... i have a question ... is it possible to assign a different name to wifi 2.4ghz and 5ghz? i want to connect some devices only with 5ghz wifi .. Thanks
schumaku
Dec 14, 2019Guru - Experienced User
Dozens of threads already on this *** subject - unsupported hacks, even worse mods, ... chakges lost on reboot, new firmware updates, ...
A dual band client will connect to the better 5 GHz _if_ the signal is really good enough. What's the fuzz?
- michaelkenwardDec 15, 2019Guru - Experienced User
schumaku wrote:
Dozens of threads already on this .....
For example:
Re: ORBI RBK50/RBS50 Tips, Tricks, Hidden Secrets,... - Page 4 - NETGEAR Communities
Betreff: How to set a separate SSID for the 5 GHz ... - Page 20 - NETGEAR Communities
