Fasco82
Dec 14, 2019Follower
WIFI 2.4 AND 5
Hi at all ... i have a question ... is it possible to assign a different name to wifi 2.4ghz and 5ghz? i want to connect some devices only with 5ghz wifi .. Thanks
Dec 14, 2019Guru - Experienced User
No, the whole purpose of orbi is single ssid with band steering. The orbi will steer devices that need more bandwidth to the 5ghz radio. When you first setup the orbi, it does take a bit before it learns the association.
There's been on/off ways of making this happen but usually firmware updates correct this or the skill to do so is more than the average person has.
