tsteevie's avatar
tsteevie
wifi 6 or wifi 5 computer
I am looking to buy a new computer with wifi 5 or wifi 6.  I was told by a friend that this computer will not be compatible with my ORBI RBR50???  Do I have to upgrade my ORBI?  Thanks...
  • Thank you so much and thanks for your quick reply!
  • CrimpOn's avatar
    CrimpOn
    No new WiFi system is needed.  WiFi6 is "backward compatible" with WiFi5 (and even earlier WiFi standards).  The network adapter and the WiFi access point exchange messages about their capabilities during the connection process.  When the adapter finds an access point that supports WiFi6, it will take advantage of the situation. When the access point offers only 802.11a, 802.11g, 802.11b, etc. that's what the connection will be.
    If you plan to keep the new computer any signficant length of time, a WiFi6 network capability is what you want to buy.
    • tsteevie's avatar
      tsteevie
