HannoosH
Mar 07, 2019Aspirant
WIFI 6 with RBK50
Will the current HW of RBK50 supports the Wifi-6 update that will happen end of the year, or there will be a new HW?
Blanca_O
Mar 07, 2019NETGEAR Employee Retired
Hi HannoosH
It will be a different hardware. It is expected to be available in the second half of 2019.
Blanca
Community Team
- michaelkenwardMar 08, 2019Guru - Experienced User
Blanca_O wrote:
Hi HannoosH
And it might be wise to wait a bit, for bugs to be squished, before shelling out any cash.
- schumakuMar 08, 2019Guru - Experienced User
And it's worth checking the fine print - both Wi-Fi 6 platforms Netgear has deployed on the RAX80 (AX8) and the RAX120 (AX12) currently don't fully comply with the formal specs as of writing.
