HannoosH
Mar 07, 2019Aspirant
WIFI 6 with RBK50
Will the current HW of RBK50 supports the Wifi-6 update that will happen end of the year, or there will be a new HW?
harisadhu
Jul 12, 2019Aspirant
Hello,
What is the release data for WIFI6 with RBK50 ?
Thanks,
Hari
- schumakuJul 12, 2019Guru - Experienced User
Hi Hari,
harisadhu wrote:What is the release data for WIFI6 with RBK50 ?
No Wi-Fi 6 on the RBK50 - new hardware generation is required.
- harisadhuJul 12, 2019Aspirant
I am actually planning to buy a most latest and greatest Orbi's mesh wifi Router. What do you recommend ?
Thanks,
Hari- michaelkenwardJul 12, 2019Guru - Experienced User
Hard to tell with no idea of your needs, budget and circumstances.
Start here:
Best WiFi Router | Best Mesh WiFi System | Extended WiFi | Orbi by NETGEAR
