Mikelm31
Aug 20, 2017Aspirant
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
- Aug 20, 2017Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
peteytesting
Aug 20, 2017Hero
the orbi system will work with anything that doesnt need a modem , in cases where a modem is needed it need to be ether bridged or the orbi system ran in ap mode
- Mikelm31Aug 20, 2017AspirantDoes the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
- peteytestingAug 20, 2017Hero
no the orbi hooks up to an ethernet port on your upstream modem in your case the huges modem , the huges would still work as normal and you would just disable its wifi then connect the orbi system and run it in ap mode
- Mikelm31Aug 20, 2017AspirantThanks I'll order one or. Pick it up at Walmart. I believe I understand what your saying.
im assuming the huges modem is also a router , can you link to its web page for me if you dont know
