Mikelm31
Aug 20, 2017Aspirant
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
- Aug 20, 2017Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
Mikelm31
peteytesting
Aug 20, 2017Hero
no the orbi hooks up to an ethernet port on your upstream modem in your case the huges modem , the huges would still work as normal and you would just disable its wifi then connect the orbi system and run it in ap mode
