Mikelm31
Aug 20, 2017Aspirant
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
- Aug 20, 2017Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
peteytesting
Aug 20, 2017Hero
im assuming the huges modem is also a router , can you link to its web page for me if you dont know
Mikelm31
Their router has my computer, phone both plugged in to it . Not very big
- peteytestingAug 20, 2017Heroso its a router as well , in this case the orbi would need to be ruun in AP mode
- Mikelm31Aug 20, 2017AspirantAP mode , does it still plug in with earthnet cat 6
Mikelm31 wrote:
AP mode , does it still plug in with earthnet cat 6yes
- Mikelm31Aug 20, 2017AspirantWould another router be better ?
Mikelm31 wrote:
Would another router be better ?depends on what you are after
wifi coverage wise you wont get better in a standard wireless router no matter how good it claims to be
feature wise you could prob do better with a wireless router but the wifi wouldnt be as good
