Mikelm31
Aug 20, 2017Aspirant
Wifi booster for Huges net Satellite
Will this work with. Hughes net Gen 5
- Aug 20, 2017Does the Orbi have phone hook up . I have Gen 5 with phone all Hughes . It's cheap gear . Signal isn't good away from router . It's ok but would like to cover 2000 sq ft
peteytesting
Aug 20, 2017Hero
so its a router as well , in this case the orbi would need to be ruun in AP mode
Mikelm31
Would another router be better ?
- peteytestingAug 20, 2017Hero
Mikelm31 wrote:
Would another router be better ?depends on what you are after
wifi coverage wise you wont get better in a standard wireless router no matter how good it claims to be
feature wise you could prob do better with a wireless router but the wifi wouldnt be as good
