pablohoney
Nov 21, 2019Luminary
Wifi Calling and Orbi
Hi, Anyone having issues with Wifi Calling and Orbi? What settings definitely work/don’t work/have an impact does anyone know? Mine is set up as a router and I have bridged my ISP provided ro...
Nov 21, 2019Guru - Experienced User
Check Beamforming, MIMO, Fast Roaming and WMM. Most of these should be enabled, however you'll need to check to see which one maybe effecting WiFi calling.
Also Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Having lots of wifi neighbors near by can me problematic as well. If this had been working before and suddenly not, then this would be something I would look into first before making any changes nor would a reset be needed. :smileytongue:
