gr8sho
Feb 28, 2019Virtuoso
Wifi Calling, iPhone X, and Orbi RBK50
Hello, Looking for some input or feedback on the use of the RBK50 for Wifi Calling. I've read a few posts about some having issues but their circumstances may be unique so I'm starting a more generic thread. The ability to conduct stable mobile calls using my iPhone X is paramount and is the main driver for getting this particular router. When such a premium is placed on WiFi Calling it is most certainly due to poor cellular reception in the household. To say it another way, if on a mobile call, should the WiFi Calling feature on the iPhone turn off, the call will most certainly drop. This has been the experience I've had ad nauseum using the router provided by the ISP for which I must lease.
Apple recommends routers with MU-MIMO support. To that end, I've made the following modifications under advanced settings to improve chances of stability although I am open to suggestions on changes. Besides these settings, the router is in otherwise factory reset mode.
- Chuck_MMentor
Do you have most recent (.32) firmware? (cant see your image yet, it has to be approved by moderator)
- gr8shoVirtuoso
Yup.
The question though is probably more historical in nature. In other words, given the provided backdrop, are users of Orbi successfully able to make and receive Wi-Fi calling calls at home . Fully transparent and no dropped calls .
- quagmire1Luminary
We've got an iPhone 7 Plus and an iPhone SE, both updated to iOS 12.1.4, on AT&T. I'm in a marginal service area - the nearest tower is about 2 miles away. On my iPhone 7 Plus, field test mode indicates my received signal strength from the nearest tower varies between -115 and -108 dBm.
WI-Fi calling works great for us on the Orbi RBK50. No issues at all.
I have experimented with the Beam Forming, MU-MIMO and Fast Roaming options. I didn't see much difference, so have left them unchecked.
I should say that my previous router, an Asus RT-N66R, also had flawless Wi-Fi calling, except in our family room (AKA, the "Dead Room"), which is now fully served by the Orbi satellite. Mesh routers rule! ;)
