Gvet
Oct 09, 2019Aspirant
Wifi Calling Vodafone UK
I am having massive issues getting my orbi set up to allow Wifi calling on Vodafone UK. The wifi calling works on any other network, so its not the phone or the service, its my orbi network. I have ...
- Oct 09, 2019
Finally!!!
Switched off the daisy chain thing and it works!
Oct 09, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I recommend not setting any PF configurations if you have uPnP enabled. uPnP should be good enough to handle port configurations automatically. If you need PF configurations, disable uPnP.
Gvet
Netgear DM200 modem
Firmware V2.3.5.30
Orbi in router mode
Has been factory reset since firmware update (and again today)
Satellite 20ft away, wifi calling works nowhere in the network (I am sat 4ft from the router). No close by wifi signals.
Made all the changes you suggested and nothing!!!
Wifi fine otherwise
UPnP makes no difference on or off.
