Gvet
Oct 09, 2019Aspirant
Wifi Calling Vodafone UK
I am having massive issues getting my orbi set up to allow Wifi calling on Vodafone UK. The wifi calling works on any other network, so its not the phone or the service, its my orbi network. I have ...
- Oct 09, 2019
Finally!!!
Switched off the daisy chain thing and it works!
Gvet
Netgear DM200 modem
Firmware V2.3.5.30
Orbi in router mode
Has been factory reset since firmware update (and again today)
Satellite 20ft away, wifi calling works nowhere in the network (I am sat 4ft from the router). No close by wifi signals.
Made all the changes you suggested and nothing!!!
Wifi fine otherwise
UPnP makes no difference on or off.
Gvet
OK, it's something in the wireless part of the Orbi. I connected an old router and wifi calling worked well with that, so not my ISP. I then connected the orbi in AP mode to the router and nothing on the orbi wireless. So it's not a router issue, it's to do with the wireless provision. But I still haven't got it working...
- GvetOct 09, 2019Aspirant
Finally!!!
- FURRYe38Oct 09, 2019Guru - Experienced User
Glad you found the cause.
Just to be sure about placement of your RBR and RBS, 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Daisy Chain is only needed for two or more satellites on the system.
Please mark your post thread as solved others will know.
Enjoy. :smileywink:
