Non-Tech
May 09, 2017Initiate
wifi calling will not connect after installing Orbi
I installed a Netgear DM200 VDSL modem and an Orbi router and 2 satellites two days ago, replacing an AC1900 Nighthawk modem/router. I'm on router firmware version V1.9.1.6 This relates to wifi ...
peteytesting
May 09, 2017Hero
hi , so is the dm200 in bridge mode as by default its in router mode and if you have setup the orbi in router mode you have dual nat and will be why its blocking the app
so you have 2 choices
bridge the dm200 and run the orbi in router mode
or
leave the dm200 in router mode and set the oprbi to AP mode
- gfreyMay 10, 2017Apprentice
I have the Orbi and I use Wifi Calling with TMobile all the time. No issues whatsoever. It has to be your modem.
