JamieC
Jul 06, 2020Aspirant
Wifi Certificate error
I have had my Orbi for over 6 months without too many issues, then today I started getting a 'Connection not private' certificate error. I have checked the timezone, all good, updated the firmware an...
Jul 06, 2020Guru - Experienced User
Is this when you connect your wifi device to the Orbi or is this on your wifi device connecting to a web site?
What device are you using?
- JamieCJul 06, 2020AspirantIt’s when I connect a WiFi device to a website, they join the Wireless network without issue Happens to all the WiFi connected devices, which is somewhat frustrating!! Wired works fine, it’s just affecting WiFi devices.
- FURRYe38Jul 06, 2020Guru - Experienced User
What web sites are you visiting if we may ask you.
I presume you have WPA2 and AES enabled on the RBR?
