JamieC
Jul 06, 2020Aspirant
Wifi Certificate error
I have had my Orbi for over 6 months without too many issues, then today I started getting a 'Connection not private' certificate error. I have checked the timezone, all good, updated the firmware an...
JamieC
It’s when I connect a WiFi device to a website, they join the Wireless network without issue Happens to all the WiFi connected devices, which is somewhat frustrating!! Wired works fine, it’s just affecting WiFi devices.
Jul 06, 2020Guru - Experienced User
What web sites are you visiting if we may ask you.
I presume you have WPA2 and AES enabled on the RBR?
