bryanchuah17
Jun 02, 2020Tutor
WiFi Channel
I have a question regarding for the WiFi Channel. Previously I am using channel 11 for 2.4GHz and channel 48 for 5GHz but then I tried to change the WiFi channel which is not congested to channel 6 fo...
bryanchuah17
Jun 10, 2020Tutor
I see... thanks for your response. So should I just leave it at there whenever I see this notice? Is it any channel also can change right? if I see that the channel is not congested
CrimpOn
Jun 10, 2020Guru - Experienced User
My understanding is that this is simply alerting the user to "the WiFi rules". Similar to when you see a sign "Traffic fines are doubled in construction zones." I believe the choice is "allow co-existence to get the highest maximum speed when possible (400) or say, "nope, I'm going with 192 all the time thank you". (Or, I could have it backwards.) I just don't mess with it.
