LSU87Dan
Apr 15, 2020Aspirant
WiFi connection issues - Orbi RBK53 and Epson P400 Printer
I followed the installation instructions that came with my Epson Photo Printer - the P400. I could not find a button on the Orbi main base that said it was for the WiFi Enables Setup. I pressed the...
Apr 15, 2020Guru - Experienced User
Are you printing the test page from the printers control panel or from the printers driver settings window on your PC?
If you connected via ethernet, you should loose features or mobility to print from places around the home.
Be sure your print drivers are up to date and the devices are correctly configured for printing.
Consult the printers mfrs support site for help and information for there printer.
