LSU87Dan
Apr 15, 2020Aspirant
WiFi connection issues - Orbi RBK53 and Epson P400 Printer
I followed the installation instructions that came with my Epson Photo Printer - the P400. I could not find a button on the Orbi main base that said it was for the WiFi Enables Setup. I pressed the...
CrimpOn
Apr 15, 2020Guru - Experienced User
LSU87Dan wrote:I followed the installation instructions that came with my Epson Photo Printer - the P400. I could not find a button on the Orbi main base that said it was for the WiFi Enables Setup. I pressed the Sync button, then held the button on the printer to initiate pairing. It appears to work.
You were correct to press the "Sync" button. See page 19 in the Orbi User Manual: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
LSU87Dan wrote:I When you go to print the test page - it sits, and sits, and sits. The printer prints about one inch of the page after over 30 minutes of waiting. I cancel the print job. I tried a regular page - same problem. It's "connected" but not connected all at the same time.
What type of computer is being used to print the test page? I suspect the issue is not with the Orbi WiFi, but with the printer configuration in the computer.
