LSU87Dan
Apr 15, 2020Aspirant
WiFi connection issues - Orbi RBK53 and Epson P400 Printer
I followed the installation instructions that came with my Epson Photo Printer - the P400. I could not find a button on the Orbi main base that said it was for the WiFi Enables Setup. I pressed the...
LSU87Dan
HP Envy - i7 chip
Never been an issue with any other printer - ever. Had this PC for years. I love how the Printer people blame the router or modem, the router people want to blame the PC or the printer...
The printer is fine. It works with a USB cable. Like a charm, better than any previously owned dedicated photo printer.
My Orbi is fine - other than allowing things to print to my new printer. This is not an issue that is not uncommon on the boards. Its almost always a router problem when you knwo the printer works.
Can someone please tell me how to get to where I can tinker with the settings and make the printer and router talk to each other. Because waiting for days for a test page to print one inch is not normal.
Maybe its the PC settings, but there is not much there to configure, actually. I'm open to tinkering with the Windows settings. Wondows cold be the stubling block. I have no faith in Windows or Apple. They both have issues.
Thanks!
Apr 15, 2020Guru - Experienced User
I recommend you contact the printers Mfr for help and information on there printer. They will be able to help you ensure the printer is working fully and is configured right.
LSU87Dan wrote:HP Envy - i7 chip
Thanks!
