jarmot
Aug 17, 2019Follower
WiFi connection often lost RBR/RBS20_AP mode
Hi, Problems - any advices? Symptoms: - drops wifi now and then - especially to iOS-devices -”wrong password to network” -message —> right password does not help -restart orbit helps ...
Aug 17, 2019Guru - Experienced User
I would try a factory reset and setup from scratch if FW was updated recently...
Please test the Orbi system directly connected to the ISP Modme with out the DGS-1008D switch in the mix. There are known issues with switches that have Green Ethernet features. Not compatible with Orbi.
jarmot wrote:Hi,
Symptoms:
System, AP mode:
1000/500 fiber —> Ubiquite EdgeRouter Lite (os 2.0.6) —> Dlink DGS-1008D switch —>
Orbi RBR20 , FW 2.3.5.26
Orbi RBS20, FW 2.3.5.26 via ethernet
I have a feeling that this started when the FW was updated to this verision.
Thank you for your help & ideas.
Jarmo
