Kkendra
Jun 29, 2021Tutor
wifi connections in air traffic flight path
Has anyone experience network interruptions (network drops oftern) when airplance fly over? I am thinking the broadcast something to the tower at the airport and it interrupts my network, same frequ...
- Jun 29, 2021
IF you had not set that up initially, then you may need to factory reset the RBR and walk thru the setup wizard with a PC and web browser. This time write down all important information for safe keeping later on.
Jun 29, 2021Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- KkendraJun 29, 2021Tutor
Well I havent figured out where I can find the settings. All I see is device manager, security, internet speed. etc. Even under WIFI settings no advance setting tab. also under router settings rbr5o no options to change configurations. this is the orbi netgear app.
Do I need to access the website itself. Netgear.com?
- FURRYe38Jun 29, 2021Guru - Experienced User
Do make any kind of changes you need to use a PC and web browser and log into the RBRs web page at orbilogin.com or 192.168.1.1
well I tried my app id and password but I got a 401 unauthorized access error and denied. It is asking me to reset my router password. Do I have to do that or just try with the router password which I am guessing the password was on the bottom of the router? :(
