Kkendra
Jun 29, 2021Tutor
wifi connections in air traffic flight path
Has anyone experience network interruptions (network drops oftern) when airplance fly over? I am thinking the broadcast something to the tower at the airport and it interrupts my network, same frequ...
- Jun 29, 2021
IF you had not set that up initially, then you may need to factory reset the RBR and walk thru the setup wizard with a PC and web browser. This time write down all important information for safe keeping later on.
Kkendra
Jun 29, 2021Tutor
I set 2.4GHZ to 11 and 5GHZ is set to 48.
