ResmoDaimac
Nov 06, 2020Follower
WiFi connections to Orbi - Latency spikes and timeouts
Greetings Any and all help is appreciated! Issue: Intermittent latency spikes and timeouts when connected via WiFi to Orbi mesh network. Impact: Makes voice communications (e.g. - Teams, Disco...
Nov 06, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What happens if you turn OFF the RBS and just work with the RBR alone?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
