Simpson_P's avatar
Simpson_P
Follower
Jul 14, 2021
wifi disconnect after 30 minutes when computer is inactive
Model: AC3000|RBK50   Hello all, Internet disconnect from my computer after un certain period of inactivity (<30 minutes). It should stay on. I know there must be something with my Orbi sttings, bu...
  • CrimpOn's avatar
    Jul 14, 2021
    Simpson_P wrote:
    Hello all, Internet disconnect from my computer after un certain period of inactivity (<30 minutes). It should stay on. I know there must be something with my Orbi sttings, but I don't know how to change settings so Internet stays on even if computer is inactive.
    If only this one PC is being affected, it might be a good idea to check the Control Panel Power Options menu, especially the Advanced Options - Wireless.  There is no setting on the Orbi that would cause it to disconnect WiFi after a period of inactivity.
