NancyS
Mar 10, 2018Aspirant
WiFi disconnect
Orbi AC 3000
NancyS
ISP is Comcast/xfinity
modem is Motorola surfboard
orbi set up by Best Buy Geek.. One unit upstairs... The blue light is on all the time. One unit downstairs.. No light
we have 2 iPhones, 1 iPad, 1 smart TV. Not all are in use at one time.
Do not have information to answer your other questions
Mar 10, 2018Guru - Experienced User
What is the model# of the SB modem? Just making sure it's a stand alone modem and no built in router.
You can try the following:
Disable Beamforming, MIMO, Daisy Chain and Fast Roaming if these options are seen on the router. Under Advanced/Advanced Settings/Wireless
Try setting manual channel 1, 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz.
Set WPA2 and AES only.
How big is your house? Sq ft.
- NancySMar 10, 2018Aspirant
Modem SBG65880. Yes it was combo modem router. House size 2500sf. As for your suggestions , I will not be able to do. Just thought there would be a simple answer as to why the light on the downstairs unit is off and the one upstairs is on. Thanks for trying anyway
- FURRYe38Mar 10, 2018Guru - Experienced User
It's recommeded to turn the modem/router in to a modem mode only if it's currently running as a router. And disable it's wifi.
This can cuase problems with the Orbi.
What firmware is currently loaded on both units?
I would try a factory reset on the Satellite and re-attach it and see if the BLUE led turn off after a while. It should not remain on.
You can try using the Orbi router by itself since you have a smaller size building as well. The Satellite may not be needed.
