ekhalil's avatar
ekhalil
Master
Oct 07, 2018
"Wifi Disconnection" issues are still in 2.2.1.210
I had big hopes that the 2.2.1.210 software would solve the wifi dosconnections. I was told by Netgear support that the issue is solved in latest beta 2 weeks ago, but it seems that it's not!
Once or twice a day, all my devices will drop wifi connection and will show 169. address.
The only thing that solves this issue is to switch off the Satellite, wait until all devices get wifi connection to the router and then switch on the Satellite.
Changing to wired backhaul improved the situation but did not solve it, so I'm getting this issue 1-2 times a day instead of 5-6 times a day with the wireless backhaul.
This is really very disappointing!
  • 26 consecutive hours now with no Wifi issues 😳First time since I had the Orbi!
    I disconnected the wired speakers (LG Soundbar and 2 surround speakers) from the Satellite and kept them disconnected for a full day, and guess what, all my problems are solved!
    1. No iPhones showing as wired in "Attached Devices"
    2. No filled Logs with spam DHCP messages
    3. Most important, is that I don't experience any Wifi disconnects any longer.
    Conclusion -so far- is that there are "some" devices that Orbis don't like to be wired (to the Satelites in my case), and if connected they will disturb the whole system.
    The speakers I mentioned are part of a Multi-Room music system similar to Sonos. It's called LG Music Flow System.
    It's a mesh-type of music system and it seems to disturb the Orbi when connected to the LAN ports. I reported this to Netgear Support and provided logs for them to analyse. Hopefully they will find a solution to this so I can get my speakers connected again!
    At least the Orbi is working now, I hope it will continue working 😅
  • Since the update my wifi no longer works and the satellites can't seem to stay connected.
    • FURRYe38's avatar
      What is the Mfr and model# of the IP modem the Orbi is connected too?
      What is the Mfr and model# of the ethernet switch if one is in the configuration.
      What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
      MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      Try a factory reset ON the entire system and set up from scratch. Walk thru the setup wizard and set up the system after the FW update.
      Let us know if this helps.
      • ekhalil's avatar
        ekhalil
        Master
