robgardien
Dec 20, 2019Aspirant
Wifi drop
I am having Wi-Fi dropouts with my Orbi configuration. I have the following setup: - RBR40 router in AccessPoint mode - RBW30 Wall Sattelite with 5G backhaul - RBS20 Sattelite with wired backha...
robgardien
Dec 21, 2019Aspirant
Removing the 2 sattelites did not work, now testing with one sattelite connected. Any other suggestions? Thank you for your help
Dec 21, 2019Guru - Experienced User
Manually download v2.5.1.8 FW for the system. Unpack the files, then manually update the RBSs first, then the RBR lastly. Factory reset the entire system. Walk thru the setup wizard. I would not add the RBS just yet. Just setup the RBR and see if the RBR changed behavior with the wifi drop. Does it still happen or no?
- robgardienDec 21, 2019AspirantI am unable to update the firmware to that version, because that version applies to the RBR50 or RBS50 and my router is a RBR40 and my sattelites are also not of the type RBS50. I get an incompatibility error so is there a version of that firmware for my setup? Thank you for your help
- mynameisjohnjDec 22, 2019Aspirant
Just to chime in - I'm having no end of problems with a similar setup (RBR40 with 3 RBS20 satellites.) I can't seem to get a stable connection for more than a few minutes without a drop.
I've updated to the 2.3.5.34 firmware version but still have no luck. Things were working fine for the first 4 months of owning the Orbi, but one day it was like someone flipped a switch and everything stopped working...
I haven't tried disabling the 2.4Ghz broadcast... it's disheartening to read that it didn't help your situation.
- John
- robgardienDec 23, 2019AspirantWhat firmware where u using when it was working fine ? I started with a RBR40 and a wall plug RBW30 and purchased the RBS20 hoping it would solve the problems, but it has never worked, even without the sattelites. The backhaul states a good connection both wired and wireless
- robgardienDec 28, 2019AspirantYes it still drops, i cant find that version for the RBR40
- FURRYe38Jan 08, 2020Guru - Experienced User
Any progress on this?
- robgardienJan 09, 2020Aspirant
No unfortunately no progress, the dropouts have become less frequently to occur but my phone still disconnects after a certain period of time
