ElMotor
Jul 07, 2018Guide
WiFi Dropping daily, Upon Reconnect, "Incorrect Password" Firmware: v2.1.4.16
Affects all devices on site. Nest Cams, iPhone 8+, iPads, Asus Laptops All devices with latest firmwares and drivers as of 7/8/16.
Troubleshooting History of Settings Beamforming : OFF MU-M...
Jul 08, 2018Guru - Experienced User
Use this same configuration:
Currently Troubleshooting Settings:
Beamforming : ON
MU-MIMO: OFF
Fast Roaming: OFF
What is the mfr and model# of the ISP modem that the Orbi is connected too?
What channels are you using? Try manual channel 1, 6 or 11 on 2.4Ghz.
Any other wifi neighbors near by? If so, how many?
- ElMotorJul 08, 2018GuideNeighborsNot many neighbors, its a house with space between houses.
ModemXfinityxFi Advanced GatewayROUTER INFORMATIONHardware Version RBR50 Firmware Version V2.1.4.16 GUI Language Version V1.0.0.314 Operation Mode Router LAN Port MAC Address ***********:A9 IP Address 192.168.1.1 DHCP Server On INTERNET PORTMAC Address ***************:AA IP Address *.*.49.166 Connection DHCP IP Subnet Mask 255.255.254.0 Domain Name Server **************
**************WIRELESS SETTINGS (2.4GHZ)Name (SSID) ****** Region North America Channel 11(P)+7(S) Mode Up to 400 Mbps Wireless AP On Broadcast Name On Wi-Fi Protected Setup Configured WIRELESS SETTINGS (5.0GHZ)Name (SSID) ******** Region North America Channel 36(P)+40+44+48 Mode Up to 866.7 Mbps Wireless AP On Broadcast Name On Wi-Fi Protected Setup Configured GUEST NETWORK (2.4GHZ)Name (SSID) ***** Guest WiFi Wireless AP On Broadcast Name On Allow guests to see each other and access my local network Off GUEST NETWORK (5.0GHZ)Name (SSID) ***** Guest WiFi Wireless AP On Broadcast Name On Allow guests to see each other and access my local network Off
