Lyenyo
Apr 28, 2019Aspirant
WiFi dropping (LAN is fine)
Hi all, I purchased this system in November to resolve WiFi signal at the back of the house. I have absolutely fantastic signal now but unfortunately within the past 2 months I’ve been having sporadi...
SW_
Apr 28, 2019Prodigy
Lyenyo wrote:
I’ve been having sporadic WiFi dropouts (devices are still connected to the Orbi but they say no internet). Computers connected via LAN to the ORBI router are fine, it just seems to be WiFi connected devices. WiFi service normally resumes after 10mins.
To rule out Orbi/Satellite backhaul problem, go to this page and check the "Status". Does it say "Waiting for connection" or something else?
Lyenyo
Hi there,
The firmware page looks fine, all 3 are saying “no new firmware available”. I have yet to check this during the droppage though. Most times I fire up the app via remote management and check the status of the satellites (which are green).
I will check this tomorrow though when it drops again.
- SW_Apr 28, 2019Prodigy
If you have good backhaul connection and there's no WiFi drops right now, that's a good sign. Yeah, check it again when WiFi starts dropping...
- LyenyoMay 01, 2019AspirantSorry for the delayed reply, I had no drop outs yesterday but it seems to have started again today at 6:33pm.
I checked the firmware page and the router says “no new firmware” but both satellites were sitting on “please wait...” which I guess means it couldn’t talk to them.
WiFi came back up 12mins later but I did capture a log file in the run up which is attached.
As for the satellite 1 being too close, I’m in doubt that would be the problem.. the house is old so the materials are thick and with a ceiling and wall I would imagine his would add up to about 30ft. I never had this issue in the first couple of months.
http://i68.tinypic.com/25s62l0.jpg
I’ve changed 2.4Ghz channel to 11 so we’ll see how that goes. Also, does 20/40 coexistence under 2.4Ghz settings make much different if it’s on/off?- FURRYe38May 01, 2019Guru - Experienced User
Try the suggestions to see if anything helps. Hopefully migth help setting a manual channel.
Unchecking 20/40Mhz sets the channel width to 40Mhz only. So if you don't have any older wifi devices, mainly B and G mode devices that only support 20Mhz, then you can set 40Mhz only. If you do have older devices that only support 20Mhz, then you may need to leave 20/40Mhz enabled.
What version is currently installed on the RBS and RBR?
